FS:Nickel plated Copper P60 modules. XHP-70 3000+ OTF lumen!
Hi all, >>>>>>>>XHP 70 OPTION and NEW HIGH OUTPUT DRIVER<<<<<<<<<
12/17/15 New Nickel plated bulbs now available!!
Copper will tarnish over time, but the new nickel finish remains bright for a lifetime!
These bulbs are for Surefire 6P. They will also work in a variety of other P60 hosts, but use of copper tape may be requried to ensure proper heat transfer.
EMITTER OPTIONS
XHP-70 N4 6500K
XHP-70 N4 5700K
MT-G2 Q0 5000K
Power source is 2x li-ion ONLY ( batteries NOT included)
Usable combinations are as follows.
1. 2x IMR 16340s
2. 2x IMR 18350s
3. 2x 18650s that are at least 6-7 amp capable.
DO NOT USE lithium primary cells.
DO NOT USE standard NON IMR 16340s or 18350s.
IF you still are not clear on what cells you can and cant use or why please ask. There is no shame in asking for help:thumbsup:.
DRIVER OPTIONS
In the new version the standard 3000ma driver will be replaced with an FET board which is essentially direct drive giving much higher currents, up to 7+ amps depending on emitter VF and what cells are used. If anyone prefers to still have a cap on the output 7135 drivers can still also be used.
OPTION 1
Adventure Sport UI™
The UI consists of 4 groups.
1. Ramp mode low to high with memory.
2. Low 2%, Med 25%, High 100% with memory.
3. Low 2% Med 25%, High 100%, Srobe, SOS, Beacon, NO memory.
4. High 100%, Low 15%. No memory
The light will come preset to your choice of group if needed.
Mode groups are switched by 8 fast clicks <.25 sec.
Here is a video of the UI in action.
http://www.youtube.com/watch?v=NSSQxqZH290
OPTION 2
DrJones Universal guppy2drv Firmware
This firmware can be left with the programming mode "open" so all of the groups are available. Or you can choose ONE and it can be permanently locked in essentially giving you only the modes in the group number. It also offers a "tubo timer" option to prevent over heating.
This firmware allows the ultimate in user customizability, with 24 built-in mode groups, that the user can select via a series of button presses and a user programmable turbo timer that will automatically step the power down to 50% after the set time is hit (see below for instructions).
User Selectable Groups:
Guppydrv Instructions
To switch mode groups: rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch the same number of times as your desired mode group. The light will blink and your mode group will be memorized.
Example: To select mode group 3, tap the switch 8 times quickly to enter programming mode. As soon as the light enters programming mode and beings flashing, tap the switch three times. The light will blink to recognize the mode group change.
To set the turbo timer: rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch 30 times to enter the turbo timer set mode. The light will then switch to 100% power. When the light is at the desired temperature for the turbo step down, turn the light off. The turbo timer will then be set. The turbo timer steps the light down to 50% regardless of the mode group set.
To disable the turbo timer simply go into program and cut it off in >3 seconds.
[TD="align: right"][/TD]
OUTPUT DATA
Copper P60 XHP-70 FET driver
2x IMR 18650s 5.89A
To............3874
30 sec......3313
1 min.......3247
2 min.......3161
3 min.......2940
2x IMR 18350s
To...........2943
30 sec......2254
1 min.......2227
2 min.......2392
3 min.......2508
MT-G2 with FET driver
2x IMR 18650s
To...........3019
30 sec.....2650
1 min.......2577
2 min.......2478
3 min.......2402
2x IMR 18350s
To...........2283
30 sec......2125
1 min........2016
2 min........2062
3 min........2082
New XHP-70
MT-G2
I really dont know exactly how to describe the beam from this accept to say WOOOAAAHHH! The MT-G2 emitter coupled with the MOP reflector provide the softest smoothest beam you will ever see. Zero artifacts. To sum it up I would say its very similar to a mule IF a mule could throw. It has a full width beam and just enough hot spot to call it a spot up close. I would say its reach is about 3-5 times that of a mule.
Control shot is Surefire 6P with over driven 9P incan bulb.
Copper MT-G2 bulb with 2x 18350s
And again 6P with 9P bulb
Copper MT-G2 bulb
For fast easy checkout (social login), multiple shipping options and product discounts please check out from the website. IMR 18350s and IMR 18650s now available there as well.
For altertanive checkout via paypal/cpf
Price XHP-70 or MT-G2 with H/O driver$159 each
World wide shipping is FREE!
PP is [email protected]
If you would like to added to the list for the current batch please post your "I'll take" and the number of modules followed by immediate payment. If you do not pay, you will NOT be added to the list.
Please also be sure to add your CPF handleand what your ordering in the paypalnotes!
Batch 1.
1. drillbitz11(shipped)
2.Moshow9(shipped)
3. ftumch33(shipped)
Batch #2 list
1.weed099 x1(shipped)
2.Cerealand (sport UI) x1(shipped)
3.Silgt (sport UI) x1(shipped)
4.yellow (sport UI driver set to #2, 90% at max) x1(shipped)
5.flat-ray (sport UI 4000K warm) x1(shipped)
6.Timbo114 (sport UI) x1 (shipped)
7.autogiro (2 mode low, high no mem.) x 2 (shipped)
8. Marten ( sport UI) x 1(shipped)
9. FIVEMEGA ( 2 mode low high) x1(shipped)
10. Tedfs (Single mode, Direct drive) x1 (shipped)
11. A.marquardt ( single mode) x1(shipped)
12. OneBigDay ( sport UI) x1(shipped)
13. MMD (Sport UI 4000k) x1(shipped)
14. gsteve (sport UI) x1(shipped)
15. lightlover x2
16. Jmayot (4000k sport UI) x 1(shipped)
17. jvvjvv (3 mode no memory) x1(shipped)
18. kellyglanzer (3 mode l,m,h no memory) x1
19. FlyFlash ( sport UI) x1(shipped)
20. Ladd ( sport UI) x 1(shipped)
21. Dirty Wage Guy ( sport UI) x 1(shipped)
22. engeneermatt ( sporty UI) x1(shipped)
Batch 3: XHP-70, or MT-G2
1. Ladd ( XHP,sport UI) x 1 (EDIT as per PM)
2. Mhgarcia114 (XHP, guppy open) x1 (Shipped)
3. seasam (XHP 5000k guppy open no braid) x1 (shipped)
4. jvvjvv (XHP 5000k guppy lock 22) x1 (shipped)
5. Chauncey Gardiner (MTG2 Sport UI)x1(shipped)
6. Jay T (MTG2 4000K port UI)x1 (shipped)
7. gsteve (XHP sport UI Group 4)x1(shipped)
8. repsol100rr (XHP Sport UI) x1(shipped)
9. repsol100rr ( MT-G2 Sport UI) x 1 (shipped)
10. Jmayot (MT-G2 4000K Sport UI) x1(shipped)
11. djans1397 (XHP 5000K guppy) x1(shipped)
12. Sal415 (XHP guppy) x 1(shipped)
13. Glow Bug (XHP 5000K Sport)x1(shipped)
14. Blakbalsam (MTG2 4000kGuppy 17) x 1(shipped)
15. zoran (MTG2 Sport + 2 springs) x1(shipped)
16. repsol100rr (XHP 6500K Sport UI) x1(shipped)
17. ProBMXer1313 XHP guppy 23 ) x 1(shipped)
18. BootsandCats (MTG2 sport) x1(shipped)
19. jvvjvv (XHP 5000K sport UI)x1(shipped)
20. Danny70 (MTG2 sport UI + spring) x1(Shipped)
21. Hemiguy75 ( XHP sport UI g3) x1 (Shipped)
22. Benchrest (MTG2 Sport)x 1 (Shipped)
23. Benchrest (XHP Guppy) x 1 (Shipped)
24. ftumch33 (MTG2 Guppy)x 1 (Shipped)25. Swagg (XHP 5A Guppy 6) x 1 (Shipped)
Please note: These bulbs are very high powered and have the potential to cause fire, eye injury, burning of skin and other. Adventure Sport Flashlights is NOT responsible for accidents or damage including but not limited to fire or personal injury due to mishandling or misuse. By purchasing product you agree to these terms.
EMITTER OPTIONS
XHP-70 N4 6500K
XHP-70 N4 5700K
MT-G2 Q0 5000K
1. 2x IMR 16340s
2. 2x IMR 18350s
DRIVER OPTIONS
OPTION 1
Adventure Sport UI™
OPTION 2
- 1% - 25% - 100% | Memory
- 1% - 25% - 100% | No Memory
- 100% - 25% - 1% | No Memory
- 1% - 25% - 100% - Strobe | No Memory
- 1% - 25% - 100% - Strobe | Memory
- 10% - 100% | Memory
- 10% - 100% | No Memory
- 100% - 10% | No Memory
- 100%
- Strobe - 100% | No Memory
- ML - 2% - 25% - 100% | Memory
- ML - 2% - 25% - 100% - Strobe - Beacon | No Memory
- ML - 100% | No Memory
- 100% - ML | No Memory
- ML - 100% | Memory
- ML - 1% - 5% - 15% - 40% - 100% | Memory
- ML - 1% - 5% - 15% - 40% - 100% | No Memory
- 100% - 40% - 15% - 5% - 1% - ML | No Memory
- 100% - 40% - 15% - 5% - 1% - ML | Memory
- 100% - 40% - 15% - 5% - 1% | No Memory
- 100% - 40% - 15% - 5% - 1% | Memory
OUTPUT DATA
2x IMR 18650s 5.89A
To............3874
30 sec......3313
1 min.......3247
2 min.......3161
3 min.......2940
2x IMR 18350s
To...........2943
30 sec......2254
1 min.......2227
2 min.......2392
3 min.......2508
2x IMR 18650s
To...........3019
30 sec.....2650
1 min.......2577
2 min.......2478
3 min.......2402
2x IMR 18350s
To...........2283
30 sec......2125
1 min........2016
2 min........2062
3 min........2082
New XHP-70
MT-G2
Copper MT-G2 bulb
Batch 1.
2.Moshow9(shipped)
Batch #2 list
15. lightlover x2
