SilverFox
GCBStokes asked me to post this because he was having difficulty getting pictures to post in a thread.
I am starting this thread for him.
Here is his post:
Tom:
Thanks for the help and great talking to you! I though it better send you the pictures now before I get busy today and/or the wife and kids get to my computer! I sent you two pictures, you pick which one you think best shows what I did.
I always liked my SureFire G2 and G2Z Flashlights, and I use them outdoors in cold, damp and rainy weather. Because they are not as cold to hold in my hand as my aluminum flashlights are. However, I don't like the very sort runtime P60 Lamp Assemble and the fact that they do blowout and break! I read a great review on the G&P Luxeon LED Upgrade Modules, I thought these is the answer to my prayers! So, I got 5 of them for my G2 and G2Z, my sons and a friend also have G2 lights, and I wanted to have a spear module for when and if I get another G2 of G2Z or new G3. With each of these module came a metal spring that was needed because the G2/G2Z flashlights none metal bodies. The spring was need to make contact with metal tub inside the G2/G2Z body to work. Some say their light work without, my did not.
I went with the 3 watt module because of the better runtime, and it is more then bright enough and has good throw. With my G2s and G2Z I had the problem referred to in the Flashlightriew.com review regarding to the bezel not tighten down all the way because of the spring. And with all our G2/G2Z lights the modules didn't work without the spring. So we had the gap! The upgrade was great, we had much better light and more then double the runtime, LED reliability. So, I though I'd deal with the little gap. Yet, that GAP bugged me! I know it may sound silly, but a little thing like that just bugged me, and I didn't like the little GAP! The GAP!!!
So, I though I'd give Aluminum Foil a try, and it works and no more GAP!!!
I got a strip of Aluminum Foil, folded it over folded it over to double the thickness. Then I cut it to size to wrap around the bottom of the LED Module in place of the spring. I crimped the foil strip into the little grove where the top of the spring would have rested in order to hold the foil strip in place. I then put the module in place in the G2/GHz body, and then put the bezel on over it. The foil in my photos is 1/2 inch wide, and is wider then needed. The foil only need to be about 1/4 inch wide to work. It only needs to contact the metal inside of the G2/GHZ body. The foil works great and sense the LED should not blow or burn out, the LED should not ever need to be removed. If needed, one could always put a new foil strip on it. I have 3 Age's and 1 GHZ that I've done this with, and all the of them have been used extensively sense April of 2006 and have not failed or needed to be re-done. And that darn GAP is Gone!
Here is his post:
Tom:
