Sold/Expired G4 D26 SUNLIGHT for $urefire
Candle Power Flashlight Forum
Help Support CPF:
Status
Not open for further replies.
CPF koti :paypal: for :
$38 for socket/reflector MOP with installed WA1185
$24 for 4 spare WA1185 bulbs
$8 INternational shipping.
Total $70
cheers,
koti.
Hi FM
I need a Socket for the SF C series; 2 C cell body I just ordered.
$32 for socket/reflector MOP +10$ for 6.6 volt, 4mm pin, 3,3amp A custom made axial bulb
total 42$
thanks
:paypal:
FM, what is your assessment of using the WA1111 with 2xIMR18500, instead of 2xIMR16340?
$41 for socket/reflector MOP with installed WA1111
$09 each extra WA1111 x 1
$8 internationaly
$58.00 total :paypal:
No soft start needed? I can use the stock momentary-on SureFire switch?
Similar question but can I use a WA1111 with 2xIMR16340 and a forward clicky switch or do I need a twisty or soft start? Newbie to incans and want to avoid :poof: and insta-flash.
This is result of my experience only and I am not recommending anyone to do or not to do.
Body is one of these 2x18650
Tail cap is $urefire twisty came out of 9P
WA1111 installed in G4 Sunlight.
2 IMR 18650
Room temperature 26C (79F)
Both cells slightly overcharged and then rested for several days.
Open circuit voltage of battery #1 reading 4.256 prior to test.
Open circuit voltage of battery #2 reading 4.239 prior to test.
Put everything together and fire it up. :thumbsup:
No instaflash, no dimming, no problem.
After 10 minutes, head was too hot to touch and couldn't hold the body with bare hands for more than 5 seconds. Tail cap was hot but still possible to hold from.
After 15 minutes, started to get dim and dimmer.
After 20 minutes, I immediately terminate the run time test and remove the batteries using some cloth to protect my hands and test the battery voltage again.
Open circuit voltage of battery #1 reading 3.548 after test.
Open circuit voltage of battery #2 reading 3.537 after test.
Both batteries were hot.
After sitting a while and cool down, battery voltage was as follow:
Open circuit voltage of battery #1 reading 3.554 after cool down.
Open circuit voltage of battery #2 reading 3.545 after cool down.
This will give you some idea that what you may expect from your flashlight keeping in mind that you may have healthier batteries, lower resistance switch, bulb from different batch and...
This is much brighter set up compare to P91, less chance of instaflash, longer bulb life and less expensive for replacement but current draw is little more (P91 2.7A versa WA1111 3.6A)
Hey Varooj, great test! :thumbsup: Right now, I'm using my 1111 with an MN socket in a SF KT on a 6P with a McClicky in the tailcap powered by 2x IMR 16340s. Until I saw your test, I was afraid to charge them all the way up to 4.22V (that's as high as my charger will go).
Seeing as I only have one 1111 right now, I didn't want it to go :poof: But knowing one held up to 2x IMR 18650, I'll charge 'em all the way!
Since I already have a G4 socket and a 2x 18500 host, I think I now need to buy some IMR 18500s! :devil:
CPF User ID: flashfiend
USPS Money Order Sent for
- G4 D26 SUNLIGHT for $urefire MOP socket/reflector with installed WA1111 $41
- 2 additional WA1111 bulbs $18
Total $59
Free shipping when paid by USPS money order
[SIZE=+1]$41 for socket/reflector MOP with installed WA1111
$5 for shipping
$46 total
Thank you.
:paypal:
[/SIZE]
The SUNLIGHT w/1909 came in, fast shipping FM! Can't wait to fire it up!
I am new to Surefire, lamp assemblies and such. Will it work with SF Centurion C3? Or Lumensfactory Seraph SP-9?
Yes (both), with the proper bulb/battery combination.
What is the function of the red metal ring that fits over the brass pill?
A spacer for using the module in SureFire brand hosts that don't use the larger outer (not included) spring.
Status
