I am looking for a good general purpose LED flashlight atleast 100 lumens powered by 2xAA with a tail cap push button switch for no more than $30. Any recommendations?
Thanks Tom
I am glad you brought this up. I don't want a thrower or a flooder. I think I need more of an inbetween. I guess you could say this is most likely to be used as a task light. If the power goes out during a hurricane or I need to look around outside at night or working on the car type of light. I am now willing to go $40 if necessary. It has to have the momentary on and off tail switch I want the high setting to be more than 100 lumens and low setting maybe somewhere around 40-50 lumens. It has to be powered on 2XAA. I have lots of Eneloops and chargers so the batteries are already taken care of. Honestly I was looking at Going Gear at the Klarus ST20 for $40 and I likey, But they have been discontinuedBy "General Purpose" - do you mean its not meant to do anything in particular? (AA batteries have very little power compared to lithium ion cells, etc...so you get relatively short run times and a dimmer beam....and are your limiting factor after cost) Depending on what you mean, 100 lumens could be OK, or too weak. If the 100 lumens are in a tightly focused beam, it might reach further, but illuminate very little in area (A little spot of bright light is very difficult to use for task lighting). If the 100 lumens are in a broad, floody beam, it could be ok for close up task work, taking a walk w/o tripping....but not see very far away. And so forth. What would you like the light to be able to DO? A "General Purpose Light" is akin to a "General Purpose Screwdriver"...it may or may not do what you need it to.
