fire-stick
Any time anything electrical is turned on, (not the little stuff, just the big stuff like the lights, and the heater), a LOUD squeaking sound is made.
I thought, change the belt... I did... now it has a new belt and it's plenty tight, but it still squeaks.
The only think the alternator belt hooks to is the main pulley at the bottom, (crank), and the water pump.. and the water pump is brand new so I don't see it making much drag on the belt..
I just listened to it outside and it really doesn't sound like the sound is even coming from the belt (the belt isn't slipping it looks to be running the same rate as the pulley) The sound is seems to be coming from the back of the alternator. Plus whenever the alternator is engaged it kinda bogs the engine down..
So, could it be the battery, alternator, belt, belt tension, any connections? Please any input will be much appreciated.
