here's a "review" of sorts.....
First, I disqualify myself to make judgemental reviews of MultiTools, since I am definitely not a Pliers or MultiTool afficinado -
I mean this is the level of "sophistication" in the typical "pliers" I use....
Not only that I have not had any need to carry a pair of pliers - regular or multiTool - on a daily basis - so I do not have any real experience of any EDC of multiTools.
However I have owned MultiTools since the first Leatherman SuperTool.........
So here are some comparison pictures and a few admittedly non-expert and "biassed" comments -
Look at the Gerbers opened - there is no room between the handles - look at regular pliers and the handles are NEVER that close together. Whereas both the Victorinox and the Leatherman have got it kind of right with parted handles so that one can get a finger in there to part the head/release the grip.
Closed - the Gerber Sportsman Multi-Plier that I just got for $5 - is the largest of all the multiTools that I have. The Gerber 400 series Compact MultiTool is smaller when fully opened - but not really that much more compact when closed.
Pouches -
Getting at the Pliers -
The Gerbers are tops here since one can simply snap the pliers head out to deploy.
Both the SwissTool and the Leatherman can be snapped and swung open one handed (kind of like a butterfly knife) -
but make sure one has a really good grip on the handle - otherwise the multiTool might go flying across the room /ubbthreads/images/graemlins/blush.gif
Extracting any other tool from the handles -
Boy, other than Victorinox have they got this WRONG -
One can open any in-handle tool on the SwissTool when closed - ie: the way the tool is carried without any fuss or extra operation......
Whereas both the Gerbers and the Leatherman SuperTool - need to be opened wide enough to get at the in-handle tools.
With the Gerbers one does need to deploy the pliers head before the handles will even part.
The Leatherman SuperTool - look at the way the tools clump on extraction. I do know the more recent models have tools that do not clump - but nevertheless this is really CRUDE.......
Closing the in-handle tools is just as convoluted with the Gerbers and Leatherman.
Even when a MultiTool is like the Victorinox and one can extract the in-handle tools without any extra operations - I still have a major objection that they just do NOT make good knives - even though the knife blades on the Victorinox are essentially the same as on SAKs -
so howcome?
Look at the way the knife blades sit in relation to the handle -
The Gerbers and Leatherman both have handles extended way below the edge, even though the SwissTool has got that bit right - it still has part of the handle way above the line of the spine of the blade.
Neither of these attributes make for a good knife -
compare it to the humble SAK and see the simple difference.
The SAK is a knife with useful tools -
MultiTools are Pliers with useful tools in the handle -
but they canNOT substitute for a knife for me.
Again I know people have solved this problem by carrying a separate knife along with the multiTool....
But I have need of a Knife on a daily basis -
but NO need for Pliers -
so why would I even contemplate carrying a multiTool on a daily basis?
