I recently got some NSPW500BS-B1S and they have a faint but distinct blue ring at the outer edge of the hotspot.
Also, if you look carefully, the hotspot is not entirely uniform.
It consists of a bluish colored round area which is slightly off centered when compared to the hotspot.
Surrounding about 270 degrees of this bluish portions is a more greenish yellow crescent moon shaped area. At its widest point, this "moon" is about 10% the width of the hotspot.
Together, the round blue area and the moon shaped yellow area form an almost circle which is surrounded by the blue ring.
From what little I know about LEDs, I figure the the blue is where the light from the LED dominates, the yellowish color is where the light from the phosphor predominates, and the ring is from some optical effect associated with the "dome". I believe that if the dome was PERFECTLY alligned with the active portion of the LED, there would be no "crescent yellow moon".
I don't intend all of this to sound worse that it is. The irregularities are almost negligible unless a single LED is projected onto a white wall, and become nothing when multiple LED are used. These are very good
LEDs - the best 5mm I've ever seen.
