I came to the light...
- Joined
- Nov 4, 2007
- Messages
- 1,059
A while ago I gave my father a 9AA Mag85 as a gift. His reaction: ... . Where'd the light go?
The runtime just isn't long enough, and the batteries (Duracell 2650mAh) self discharge too quickly. Now I'm going the rectify that problem, but I'm not sure exactly which way is best. I was hoping I could just buy 3 D li-ions, but it seems like those are very hard to get at a high enough quality for this high-current mod.
In case you're wondering, no, I can't just swap in LSD AAs, because the runtime is already too low.
Alternatively, I could get an LED dropin, but then I'd have to scrap everything I've done so far. Which would be OK, but I can't find anything close to as bright as a WA1185 that will use regular D cells (4.5v total). If I were to use a higher voltage, then I could save a bit of money and keep the WA1185. The only configuration that I can see working is 9xAA eneloops and a P7 or MC-E dropin, but the only fitting dropin I've found is Malkoff's, which by itself is ~2x the price of the entire original mod.
So I guess the second solution I can see would be to find a cheaper quad-die dropin, at any voltage, and swap the duracells for eneloops if I can't get a 4.5v dropin. Any help there?
Also, do you see any other way I could keep the light at around 1000 lumens, increase the runtime, and decrease the self discharge rate, all while keeping the cost under $100? (keep in mind I'd sell unused parts)
Thanks for reading (and sorry it was a bit long)
