Gladius tail
Nitroz
Monroe
Has anyone disassembled a Gladius tail cap? Just curious if this can be taken apart.
I need to be able to fix mine. When I first received mine I did not know about the alignment pin and chewed it up when taking the tailcap on and off.:banghead::stupid:
Well:poke: Give us some ideas on how it is done.
Ok I cut my *** away from the computer and took new pics. can you mod the title to say pics - lots of them?
Gladius tailcap disassembly. Tools needed – small slotted screwdriver, small pin punch, needle-nose pliers.
insert screwdriver in between push button and selector ring
pry away from switch assembly
remove button
insert screwdriver between selector ring and tailcap – pry it off and remove
you will see the ball bearings in here – I think I lost one as they spilled out when I removed the selector ring. I replaced them for the photo.
different exposure
bearings removed – you can see the relief groove where the bearings sit in
I pried this collar out then
the post inside has a pin in it. This pin holds in a spring which wasn't in there from the last time I took it apart. Yes I had parts left over.
pin punch the pin out and/or use pliers to pull out once started
you can see the indexing rollers on the larger pin inside here.
the aluminum collar can be removed….actually you can remove it a couple of steps sooner if you want.
metal (anodized aluminum it appears) housing inside the aluminum collar – there is a SMALL pin here. This is the pin that aligns the tailcap onto the body when replacing the cap.
use pliers to pull it out
this allows the center post to come out further to access the indexing rollers. I had to pry a bit using the screw driver in the opening on the post.
here is the opening – a SLOT
roller set up with one spacer and roller off.
the center post can now be pulled out. You can see the teeth that the indexing roller indexes against.
center post can be removed from the toothed collar
the center post has a magnet installed. Part of the on/off
ball bearing stuck to magnet for illustration purposes.
here are a bunch of parts laid out
here is that spring I mentioned earlier….I do not remember how it goes in…I believe the pin holds it in.
here is the groove that holds the ball bearings in
Now don't ask me to put it back together…just go backwards!! ;-)
Boltgun
SORRY ABOUT THAT _ SOME KNUCKLEHEAD TRIED TO ORGANIZE HIS PHOTOBUCKET ACCOUNT ;-)
Too bad the pics are down :sigh:
Boltgun, could you please reupload them if you still have them ?
Thanks
edit: thanks, now I can see them. ;)
Thanks for the Pics I might have to take mine apart as once and a while it does not work. I called Blackhawk for warranty and they want me to purchase a new tail cap for $70 :shakehead
Many thanks for the pics, much appreciated!
I put white Silicone thermal grease in the Gladius body slot/channel so that when the tailcap pin is inside, the grease provides electrical contact too. Any conductive grease will prevent intermittent operation but one needs to put grease in the body slot/channel from time to time.
If the tailcap pin can be pulled out, I hope we can change it to a longer one to fix the intermittent contact.
TTTGTH.........:poke:
