[ QUOTE ]
I found, by trial and error experimentation, that blue, white or UV light will charge up the glow-dust, while red, orange, slime-green and true green don't. There must be a maximum wavelength cut-off around 500 nM.
/ed B in NH
[/ QUOTE ]
As was pointed out above, a photon must "bump" an electron up to a higher level. Due to the nature of quantum physics, this "bump" must have at least a certain amount of energy to work. If a photon does not have enough energy, all you get is heat. This means that each substance has a minimum wavelength of light that is needed to charge it.
Since similar substances are used in a white LED, this explains why you need a blue LED before you can make a white one. Putting phospor on a red LED would not work for this reason.
