GoingGear.com - Olight 3600mAh and 3200mAh 18650 Lithium Ion Batteries
GoingGear.com
Atlanta, GA
The Olight 3400 mAh 18650s have been one of our best selling items from the first day we received them, so let's give you some more options.
Olight now has the brand new 3600mAh and the 3200mAh 18650s. The batteries feature protection circuitry, long life, low self discharge, raised positive polarity and a high discharge current. The lifespan of both of these batteries is 500 charge-discharge cycles over 5 years of consistent use. These features allow for higher run time and a safer battery. Just like the existing 18650 models, each 3200 and 3600 18650 comes with a free storage case that can safely store 2 x 18650 batteries.
We have the 3200 and 3600 18650s in stock and ready to ship right now.
Olight 18650 3600mAh
Olight 18650 3200mAh
Raysbeam
Alberta Canada
Do these batteries have the same protection circuitry and use Panasonic cells like the 3400mAh? I have read they are customized 18650's
Raysbeam
Alberta Canada
Thank you very much, If the 18650 that comes with the S30R II is customized does Olight not recommend charging the regular 3200,3400,3600mAh 18650's inside the flashlight? Also is it not recommended to charge the customized 18650's in the Omni Dok?
GoingGear.com
Atlanta, GA
You can't charge the regular 18650s in the S30R II. The customized batteries have the negative and positive connections on the traditional positive side while the negative side is just negative. The customized batteries are button tops, so I don't see why they couldn't be charged in the Omni Dok since the negative on the positive side shouldn't make contact.
Raysbeam
Alberta Canada
Thanks again! I really appreciate you taking the time to make your customers more knowledgeable about your products, and all the time you take making YouTube reviews it's very helpful and shows how much you care about your business. Great work everyone at Going Gear and many thanks.
