GoingGear.com - Olight S30R II Baton 3200 & 3600 18650 1020 Lumen Rechargeable Light
GoingGear.com
Atlanta, GA
The Olight S30R II Baton flashlight is here! The S30R II, the updated version of the S30R, has updated specifications that increase its performance and reliability. The original S30R had some issues (please contact Olight or us for repair/replacement if yours has issues) where dust and lint would get in the tailcap, creating too much resistance for operation and charging. Yeah, you could take your light apart, clean it, and make it work again, but that's no fun. Olight has instead completely revamped the light and thoroughly tested it for durability and reliability. They have fixed the charging issue, bumped up the output, and improved the switch.
The light ranges from 1 to 1020 lumens, has a XM-L2 LED, and comes with 1x18650 battery. The light can also take 2x CR123A batteries if you are in a pinch. The side switch allows for 5 different brightness levels in addition to a strobe mode. The new version gives you the option to choose between an included 3200 mAh 3.6V or a 3600 mAh 3.6V battery. The S30RII, like the S30R, has a magnetic tail cap, a micro-USB charging dock, and a removable pocket clip.
These are both in stock and ready to ship!
Olight S30R II Baton 3200 mAh
Olight S30R II Baton 3600 mAh
