Leeoniya
any advantage to iron plated tips in smt soldering applications?
i've had gold plated tips which are a good amount more expensive, it seems the plating goes away because of the heat after very little use (cause gold melts at low temps?)and reveals...copper? which obiously needs to be tinned otherwise it renders it useless cause it sticks to everything you're trying to solder...huh?
i use rosin liquid flux, but i hear solder paste is better for SMT. any recommendations on manufacturers? MG chemicals? also, does it double as temporary adheasive to stick tiny components to their pads as I solder? i only have 2 hands people!!
thanks
Leon
thanks
Leon
