Thanks and that may be where I end up. The housing is proprietary so I hoping to just replace the guts.
I am thinking of using something like this?
Thanks,Not a lot of options out there for units like that with the driver and emitter on one board. Your best bet is to find s suitable replscment LED, verify the voltage supplied to the oroginal driver board, then find a power supply rated for that that "bucks" (drops) the voltage down from the input voltage to a nominal 3V output for a single LED, at an appropriate current output.
What does the rest of the housing look like? Is there a large enough heatsink and thermal pathway from where the LED will sit to the heatsink to allow more power to be pushed through the LED?
Hi,
I bought a Luxceon C white 1-up but it does not seem to put out much light?
Not sure what to expect?
Lets talk about the lens. Anyone know what I can expect from the lens??
thx
randy
Thx for all the help!! I just trying things out. I found 10 watt 12 volt led that may work. I fitted to my existing heat sink. I think it is may be the answer. I am not sure if I want to run it at 12 volts but? but it was very bright!!
I need to check it out at night!!
I'll keep you updated. and thanks for all the help
randy
Thanks EJR. Here is the original led.
Thanks EJR. You solved my next adventure in mounting them to a PCB. . or is there a youtube on mounting them to a PCB??
Now to build a LM317 driver!!!
Randy in COLD florida
