Hi all,
I'm new to this area (LED flashlights). I've been reading the 'batteries included' area for over a year though due to battery needs - and I simply LOVE my Maha C-9000!!. I've also sorta been a flashlight junkie my whole life though.
I just got the Walmart Coleman Max Cree XR-E 2xAA as my 'step-up' light into the world of higher-end flashlights. All I can say now is -- "I'M HOOKED!". No more wimpy flashlights that quickly break down for me, thank you! :thumbsdow
I'm now looking into replacing one of my 7 Dorcy 1xAAA lights... Namely my pants-pocket one. I'm looking for some real power here. The thing I like about the Dorcys is that it's a TON of flood for a 1xAAA. When I'm walking past an area of forest between two streets in my area, I whip out the Dorcy and can see any branches or whatnot that may have fallen in my path - as well as any head-level branches that haven't been cut yet. I would now like more though...
I haven't spent more than ~$12 on any flashlight until now, so I want to make sure a purchase of either $45 or $60 will be worth it for a 1xAAA light.
OK. So on the one hand, the Fennix - either model - seems to be a solid buy for ~$45. The LD01 seems to have maximum brightness that is more than the max of the L0D. However, the initial default setting(med) seems to be higher on the L0D than for the LD01. In the real world though - would I really see any difference?? (I've never had strobing/SOS type features before, so I don't know what that means to me outside of saying "COOL". :thinking: )
The other option I'm looking at is the Liteflux LF2X. It's a bit pricier at ~$60, but seems to have a lot of programming options. The downfall of the Fenix, IMO, is that after turning it off it reverts to it's default(med) setting.. A HUGE anoyance if you ask me - one that I think just shouldn't be there if one is to pay that much for ANY flashlight with modes.
Am I right in understanding that the LF2X will remember settings - even if batteries are switched out? I'm also understanding that the Liteflux LF2X will be safer to use with my NiMH's since it seems to offer a low-battery warning as well as auto-shutoff.
Does the LF2X also offer sustained output with a NiMH until it's too low to work on 'high' - without over-discharging NiMH cells?
I'm also worried about the markings on the LF2X. I understand that they might be important in order to program it. Well - in my pocket, I KNOW that they'll likely wear out pretty quick - so are there also some indentations to mark them?
In a super-quick 'rudown', how does the programming and usage work?? I hear all this about SW2, SW-6,P1,P2, pushing the headcap up/down - blah,blah -- WTF? How does that truly work?? (not in detail because I could figure that later on - I'm just not understanding the entire concept-of-use.)
I also want to make sure that the light wont turn on and/or reprogram itself simply by being in my pocket.. For instance, with my Dorcys, I have to unscrew the end-cap a few turns and test by pushing the button while wobbling it around to make sure it wont turn on, before I put it back in my pants-pocket. Will either the Fenix or LiteFlux have such problems?
As you can guess, I'm leaning toward the LF2X at this point. But I've never spent so much on a flashlight, let alone one that will fit in my pocket - and could easily get lost..
Thanks for all your help,
Brian
P.S. I'd also like to give a BIG thanks to Silverfox for all his in-depth and knowlegeable information about rechargeable batteries in the 'batteries included' area. He's the reason I got my beloved Maha C-9000 in the first place. Thanks to SOOO many others there too - like 'Mr. Happy'(off the top of my head - must be that nickname! !!
Brian
