I did another runtime test with another RCR and this time I got 24 minutes runtime out of my [/B]#8 power level Logan.
That's more like what I'd expect! Did you check voltage afterwards? Maybe the protection circuit is kicking in early.
What I do find a little strange however, and slightly disappointing, is the behavior of the light with primaries, vs. RCR's. Anyone who watched JWRitchies video should remember how low the little Logan came on when the circuit is completed at first. Then a nice gradual ramping to high. Mine works exactly like that with RCR's, but if I stick a fresh primary in it, it doesn't have near the range in output levels. At it seems kinda opposite of what you'd think. With the higher voltage of the RCR's, my light will come on low enough to look right at the emitter with no problems. But with a primary, low is way too bright to even think of looking at the emitter. It ramps up to what looks like about the same high as with RCR's, but the real low just isn't there. With primaries, it's more like it comes on in a "medium" level, then ramps up. Soooo, I guess I'll keep it fed with RCR's, but I would have rather kept a primary in it. Anyone else with this light notice similar behavior, or is mine just a little funky?
Hi Bigmac 79. Unless you twist the head very quickly, there can be some minor flickering, either direction, ramping up, or ramping down. You're right about the specs. They can be tough to find. One thing nice though, when you get on the RMSK website, you can live chat with someone and ask any questions you want. I've chatted with Bob twice now. I'm sure they can answer any questions you have. Get one of Peaks QTC lights. You won't be sorry, I'm sure!Two questions:
I really like the idea of this QTC stuff, but I've heard that the rate the brightness changes isn't very smooth, can anyone who has one attest to that?
Also, I'm just really confused by the website. I'd like to research what all their options mean, see specs, etc. I did research and in an old thread someone mentioned the path to some "hidden" files on their server, but most of that data is now outdated. Anyone know where to find specs on their lights?
Hi Bigmac 79. Unless you twist the head very quickly, there can be some minor flickering, either direction, ramping up, or ramping down. You're right about the specs. They can be tough to find. One thing nice though, when you get on the RMSK website, you can live chat with someone and ask any questions you want. I've chatted with Bob twice now. I'm sure they can answer any questions you have. Get one of Peaks QTC lights. You won't be sorry, I'm sure!![]()
http://en.wikipedia.org/wiki/Quantum_tunnelling_composite
So, if these Peaks are using the same technology... Then basically these new lights have a layer of this composite that is compressed by the battery as they are tightned/loosened, thus varying the current flow from 0-direct drive? Is that what I'm getting from this?
+1 Bob (RMSK) is very helpful and with the online chat feature you pretty much get your questions answered instantly. The thing with QTC and Peak lights is you need to understand the level of simplicity that these are built to. If you want perfect even smooth ramping go with something electronic. If you want something that will outlive the cockroaches after a nuclear holocaust even if the QTC goes belly up then you'll be happy with Peak. What I like about Peak is they just work, no gimmicks, no crazy UI, no weird electronics. IMO it's a little archaic sure but kind of refreshing as well.
