<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by vcal:
Craig, -that nasty laser sounds great!! -All except the part about "vanadate and Nd:YV04" -what the hell does that mean? (in 50 words or less) <HR></BLOCKQUOTE>
To put it as simply as possible, these are the expensive crystals inside a green laser that give it its green color.
An infrared laser diode (808nm) shoots into the Nd: crystal, this crystal then lases at 1064nm (yes, deeper into the infrared). That light then shoots into the vanadate crystal which doubles the wavelength (1064/2) into the green you see coming out the end.
An IR filter (for safety) and a simple lens (to collimate the beam) finish the job.
I did *not* count the words. I did *not* spell out the actual chemical composition of the crystals. And I did *not* mention these comprise an intracavity resonator.
What I did want to write about tonight was the FUN I had with my green pointer during the annual tree lighting ceremony in downtown Seattle earlier this evening.
I was about a block and a half to 2 blocks away from the large tree in Westlake Plaza, and about 3 blocks away from the gigantic illuminated star on the Bon Marche building.
Every year in the 15 or so minutes leading up to the tree lighting, someone in the 50,000+ crowd shoots the big empty wall of one nearby building with a red keychain pointer, and then "laser races" start going on as more and more people add their red spots to the wall. Tonight, I whipped out my greenie, and all but one of the red beams almost immediately vanish. I shined it on the wall off and on for the better part of ten minutes, chasing the lone remaining red pointer dot around on the wall.
Then they began the 15 second countdown for the tree lighting. 5...4...3...2...1...0... and nothing. Totally dead. So after waiting around ten seconds, I whip out Mr. Green Laser once again and illuminate the upper half of the tree with it for the 90 or so additional seconds it took the guy to find the light switch.
I heard several people go "look at that" and point up to the upper part of the tree where my beam was being waved around.
Once the tree lit, I put the laser away, as I figured I wouldn't need it any more.
Next up was the big "star" on the corner rooftop of the Bon Marche building. Same countdown, same results. Totally dead, except for 4 of the spokes up at the top.
So I lasered that on and off, a few seconds at a time, until the Star finally came to life several minutes later in a shower of sparks and fireworks.
I forgot all about this until the 11 O'Clock news came on - and there was my green laser spot, bright as heck, waving around the top of the Bon Marche building where the star was as the news guy described both of the lighting failures.
Turned to another channel, and my laser was on that one too, this time on the failed Christmas tree, but only for a very brief second that time.
Don't see that everyday... first time I've seen a green laser (mine or anyone else's) on the TV news.
