One of the problems with maxfleses I've found is getting all the wires into the 2 'ground' holes
Would I be doing anything wrong to use the aluminium housing as ground and creating an bolt attachement point to collect the various ground wires (power, momentary switch, warning led, main led's etc) and then just have one wire to the maxflex?
As the maxfles will also be heatsunk (heat epoxy via pad) to the housing will there be any problems there?
Lastly what about the cutter supplied mcpcb mounted crees? Will a housing included in the circuit cause any problems with them shorting out or something?
Is there something else I should maybe worry about!!
