[Group Buy] HaikeLite MT07S XHP70.2 5000lm 500m 4x18650
Wurkkos
freeme
Vendor
1thedeals.com
After purchased 5 lights from HaikeLite last month, I am totally hooked by their creations right now. You might already heard their up-coming new toy, MT07S XHP70.2 4500lm 500m from their other thread. Below are some of their new sample photos.
credit to HaikeLite
Specifications:
Emitter: CREE XHP70.2 NW 4800K
Meterial: Aluminum Alloy , HAIII Anodising
Battery: 4x18650 (Recommend Sanyo 18650 GA 3500mah 18650)
Reflector:SMO Aluminum Reflector
Lens: Double Side AR coating Glass Lens
Bezel: Stainless Steel
Waterproof: IPX8
Max Output: 5000 Lumens
Max runtime: moonlight 1 lumens--60 days
Digital Full Current Regulation
Anti-reverse protection
Anti-discharge protection
Demension: 175mm x 66mm x50mm
Netweight: 470 gram
Accessories: landyard,O rings,Tripod Mounting Screw
Brightness Modes:
Low: 150 Lumens
Medium I: 450 Lumens
Medium II: 1000 Lumens;
High: 2200 Lumens
Hidden Turbo:5000~5500 Lumens (double click at any time)
Double click again:Strobe
Hidden Moonlight:1 ~3 Lumens (In off status A long click for 2 seconds to access moonlight. )
Thermal control Remove / Activation:MT07S comes with thermal control by default. If you want to remove thermal step-down , turn the moonlight mode on first and press the switch for 3 seconds to remove thermal control function. When you see a signal flash, it means the thermal control function has been removed, and MT07S will have no step down any more.
The thermal control function will recover when you cut off the power supply.
User Interface:
single click on; single click off
Long click to change modes ; Double click to Turbo ; Double click again to Strobe ;
With last mode memory
In off status a long click for 2 seconds to access moonlight mode ; another long click for 3 seconds to remove thermal control. Cut off the battery power to recover thermal control.
Lockout Function:
A single click followed by long click to lockout the switch. Repeat to unlock.
Power indication light: (LED indicator under the metal switch button)
100%~50% Blue led on
50%~9% Blue led flashes
Blow 9% Red led flashes
Express Your Interest Below
freeme
Vendor
1thedeals.com
Interest list. No PM please.
1 freeme
2 freeme
3 casi29061965
4 Pok
5 mizou51
6 adsum
7 I_SpY
8 kotobuki
9 leroycp
10 longmire
11 fed893
12 rizky_p
13 Smittymojo
14 tonylim
15 dmsoule
16 djypo
17 SubSailorVet
18 warzi1975
19 cccpull
20 Wieselflinkpro
21 Phantom1
22 Modestep
23 g_sintornillos
24 sac02
25 Silent_Star
26 Nguyen
27 gorb507
28 vas37
29 jamaya
30 mrheosuper
31 mjgsxr^
32 Gerrh
33 nathan_nz
34 southland
35 X0R
36 DooMMasteR
37 schroeck
38 firedome
39 Gerrit
40 jmpaul320
41 Bruno28
42 charles lin
43 yasenf
44 Nicolicous
45 nfetterly^
46 moshow9
47 gerasalex
48 Kozy
49
50
51
52
53
54
55
Garnett
Is there another info thread somewhere I'm missing? Is this open to UK members, and how much is it?
