Haikelite MT09Rvn - Most Bang 4 your $$$
vinhnguyen54
vinhnguyen54
  • 4*LG 3500mAh Recommended
  • 3*XHP70.2 6500K
  • Dimension: 169mm x 74mm x 51mm (Length x Head Diameter x Body Diameter)
  • Ramping UI
  • Great build quality
  • Upscale lanyard ring and para-cord included
  • Stock Spec 1 has Factory Warranty
  • Spec 2 has Sky Lumen Warranty
Spec 1 70.2 HD 6500K 18,500 Lumen, 155Kcd Intensity
Spec 2 70.2 SD ~ 4500K 15,500 Lumen, 205Kcd Intensity
Let me know if you want Black Silver or Blue
+$5 for V54 engraving
J
jo_th
Does stock spec get any upgrades? all spring bypass, refocusing etc or 100% stock?
  • 3*XHP70.2 6500K
  • Ramping UI
Stock Spec 1 70.2 HD 6500K 18,000 Lumen, 150Kcd Intensity, 775m Throw $155
Spec 2 XHP70.2 SD ~ 4500K 15,300 Lumen, 200Kcd Intensity, 894m Throw $180
F
flybird
Only Silver color ? Understand that they offer other color like black ,blue , green .
vinhnguyen54
vinhnguyen54
Silver only for now. Other color can have mis matched color.
L
LichtAn!
Hessen, Germany
Are the carrier springs bypassed by default now or just the top spring? How much for an all spring bypass 5000K version?
vinhnguyen54
vinhnguyen54
Same price as a shave dome version. All double springs.
J
jo_th
does shave dome version get all double springs?
If all double springs is put on dome-on version will there be a increase in lumens from the stock 18,000lm?
vinhnguyen54
vinhnguyen54
does shave dome version get all double springs? YES
If all double springs is put on dome-on version will there be a increase in lumens from the stock 18,000lm? May be a little but I have not tested to know. If I add springs factory warranty is void though.
vinhnguyen54
vinhnguyen54
Which one do you prefer all things considered?
D
domho8
I go for x45vn 70.2hd
vinhnguyen54
vinhnguyen54
Problem ia x45vn is twice the price and x7vn is 1/2 the size. Hard to pick really...
J
jo_th
How come HD and SD went up 500lm and 5cd more?
What made spec 1 go from 155usd to 165usd?
L
LichtAn!
Hessen, Germany
If only the x45 came in a version with a deeper reflector. I really like the traditional spill that goes right in front of your feet. But I guess with such high output the MT09R is much more practical, because you don't blind yourself so much?
vinhnguyen54
vinhnguyen54
Aditional mods I over looked.
vinhnguyen54
vinhnguyen54
I am rarely blinded by too much spill. I always like to have as much as possible.
Similar threads
vinhnguyen54
Replies
128
Views
44K
vinhnguyen54
vinhnguyen54
vinhnguyen54
Replies
77
Views
17K
eekazum
E
vinhnguyen54
Replies
Views
2K
vinhnguyen54
vinhnguyen54
vinhnguyen54
Replies
18
Views
6K
Newlumen
Newlumen
vinhnguyen54
Replies
2
Views
2K
vinhnguyen54
vinhnguyen54
