Sold/Expired Hanko Ti Twisted Trident - SOLD
moshow9
moshow9
El Paso
Includes light and Efest 18350 IMR.
Product Description
Jeff Hanko Twisted Trident Flashlights.
Titanium Body, Bezel and Pocket Clip.
- Made of grade 5 titanium with stonewash finish.
- Ti Stamped Pocket Clip by Steel Flame.
- Tripple (3) Neutral tint (5000K) Cree XP-G2 LED's with the brightest available S3 bin.
- Narrow spot frosted optic.
- Uses 18350 cell. Does NOT use CR123.
- 3 amp driver with Guppydrv firmware. 22 user selectable groups. Something for everyone with no complicated programming required. All lights are shipped with user group 11 loaded.
- Solid C110 copper heat sink for the greatest thermal mass.
- The entire LED/Noctigon copper PCB/copper heat sink assembly is all reflow soldered at the same time using silver solder. No thermal adhesives or compounds of any kind used anywhere. The result is unmatched thermal transfer and reliability for reliable, long life.
To switch mode groups:
Rapidly tap the switch 8 times, holding the last tap. The light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch the same number of times as your desired mode group. The light will blink and your mode group will be memorized.
Example:
To select mode group 3, tap the switch 8 times quickly to enter programming mode. As soon as the light enters programming mode and starts flashing, tap the switch three times (for group 3). The light will blink to recognize the mode group change.
To set the turbo timer:
Rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch 30 times to enter the turbo timer set mode. The light will then switch to 100% power. When the light is at the desired temperature for the turbo step down, turn the light off. The turbo timer will then be set. Turbo timer drops down to 50% output.
User Selectable Groups:
1. 2% - 25% - 100% | Memory
2. 100% - 25% - 2% | No Memory
3. 2% - 25% - 100% - Strobe - Beacon | Memory
4. 2% - 25% - 100% - Strobe - Beacon | No Memory
5. 15% - 100% | Memory
6. 100% - 15% | No Memory
7. 100% Only
8. 100% - Strobe | No Memory
9. Strobe - 100% | No Memory
10. ML - 5% - 33% - 100% | Memory
- 11. 100% - 33% - 5% - ML | No Memory
12. ML - 5% - 33% - 100% - Strobe - Beacon | Memory
13. ML - 5% - 33% - 100% - Strobe - Beacon | No Memory
14. ML - 100% | No Memory
15. 100% - ML | No Memory
16. ML - 100% | Memory
17. ML - 5% - 15% - 50% - 100% | Memory
18. ML - 5% - 15% - 50% - 100% | No Memory
19. 100% - 50% - 15% - 5% - ML | Memory
20. 100% - 50% - 15% - 5% - ML | No Memory
21. 2% - 15% - 50% - 100% | Memory
22. 2% - 15% - 50% - 100% | No Memory
List Date: 8/15/2015
For more info, click here to view the original listing: Hanko Ti Twisted Trident
SOLD
candlepowerforums
moshow9
moshow9
El Paso
Re: Hanko Ti Twisted Trident
PM sent
L
lefteye219
wow, went to have lunch and what a flash sale.... congratz to buyer and seller
moshow9
moshow9
El Paso
Thank you. It is a gorgeous light and I hope the buyer enjoys it. :)
G
Gratefuljellyphish
West Des Moines, iowa
Oh I'll enjoy it alright. Thank you very much for selling it to me. I already can't wait til it gets here.
M
magellan
Honorary Aussie
USA
Congrats on scoring a very unique light.
jmoyat
jmoyat
Northern California
Yup, congrats Greatephuljellyfish, this is one fine piece and already hard to get!
S
sledhead
Appreciate it if someone could PM me the price?
Similar threads
F
Replies
2
Views
2K
FlyGuyLuciferin
F
Rstype
Replies
19
Views
4K
FlashlightFantacism
F
R
Replies
2
Views
946
rikyric
R
