Having a problem with DX 7882 and KD 3150 drivers
Bigsy
Ok, I've had 5 from DX and 5 from KD and can't get any of them to work properly. I soldered wires on 3 of them, they didn't work, so I tested the rest without soldering.
This is my setup: http://bill.hedworth.googlepages.com/setup.jpg
This is how I am wiring them up (solderless in this pic): http://bill.hedworth.googlepages.com/wiring.JPG
Just to make it clear I am taking led -ive from: http://bill.hedworth.googlepages.com/dx7880.jpg
I've been v.careful to always have the boards output loaded, and have checked the wiring a million times...If bypass the modes by taking led -ive from the IC chip leg which is closest to normal led -ive they work but in single mode.
I've used many drivers in the past dx6190 dx7880, Kennan etc etc and have never even had 1 die on me....so 10 in one go is bizzare!
Help!
The led -ive actually goes all the way through the board to the base of the leg you see in my second picture.
I actually haven't pictured me taking negative from the the mode IC leg.
HI,
I have exactly the same problem... with sku7882
See how I connected the led here : http://candlepowerforums.com/vb/showthread.php?t=192893
So I think that you connected properly the led... and that these items do not work :sick:
JP
