HDS Systems #23
LRJ88
dang - what kind of hard use environment do you EDC in? I have kydex holsters that are friction fit around the head. I use a heat gun to adjust tension. I'd be concerned of not knowing when the light popped off the magnet or I'd keep knocking it off while reaching for other things on my belt.
I work in adult education, specialising in CNC and welding. I've used some holsters for other flashlights there but iron filings etc. have a tendency to get stuck in the holsters and then after a little while you have not-so nice little hot spots where there's any kind of harder friction against the flashlight. Until i'm finally getting the rotary i've ordered i'm carrying an Olight S2R II in my pocket which works, but it's still not ideal considering aforementioned filings tend to congregate around the tail. I've attempted using my Emisars but it's a bit too oily at times for me to feel safe with the boot, and while my PD35 v2 has been working well it's a bit too large for comfortable use all the time.
What i had in mind would be something kinda like the picture here, except for only one light and a larger lip on top keeping it in place, however not enough to impede on drawing the flashlight. That way it'd be easy to just clean with some compressed air rather than having to go at it with tape, a screwdriver, and a tiny magnet.
https://www.gearuptohunt.com/resize...T_side-view.jpg?bw=1000&w=1000&bh=1000&h=1000
Mister Ed
Administrator
Staff member
Don't know who or why, but obviously some admin deleted it.
Just another reason I spend more time on the FB group than here. May leave here permanently soon.
You do know why, you were given a notice about listing items for sale without being a sponsor. If you really are going to use that as a reason to leave, not much I can do.
Hogokansatsukan
Tucson
No. I wasn't given a notice.
No. It isn't listing items for sale.
If you had followed this for years, you would know it is an interest thread. Seeing if there is enough interest to get Henry to do a run.
Much like many of the runs that have been done in the past from the folks here requesting them from 18350 battery tubes to special emitters. It starts with someone requesting it, then others chiming in... then an interest thread.
But it's your playground.
nbp
Wisconsin
Huh? That wasn't a for sale thread man. The lights don't even exist, and may never exist. If they ever do they would be sold on the HDS site. So this post makes no sense.
scout24
Penn's Woods
Wow... Not just HDS, but there have been interest threads all over CPF for years. Might be worth spelling out so there's no confusion.
troutpool
Arizona
This is a sad and disturbing misunderstanding. The thread in question was clearly an interest thread, not a for sale thread. And what exactly is a "sponsor"? What does that term mean? I see HDS ads on CPF from time to time. Doesn't that qualify HDS as a sponsor? Is it the individual supporter's badge that is the issue?
Don't go, Hogo, don't go. Too many of us here depend on your news and information about the light that gets you home.
JohnSmith
PA
Moving to Facebook exclusively will be ruinous to the community of HDS enthusiasts. It may be a platform for Hogo to communicate with customers but it's not a place conducive to reading, learning or research. All of which are important when a person is trying to decide if a $400+, 300 lumen flashlight is right for them. It will be like replacing a continuously updated encyclopedia volume with a series of text messages and emojis.
scout24
Penn's Woods
If locked, new content can always go back over to General Flashlight Discussion and have the long running HDS discussion threads of old.
LRJ88
Was this a one-mod decision? If yes, is there any kind of documentation as to what was removed, and why? As a somewhat longtime user of this site i'd be grateful to know what the unspoken no-nos are that aren't listed in the TOS.
kerneldrop
South
Does anyone have an HDS beater lying around...i'd like to drop a 519a in one.
I'm very confident that with flux paste and a hot air station we can control the heat enough to successfully swap the LED without destroying the light.
Stoneking
USA
Are you looking for someone to put up the risk of you attempting this? The light would be returned either way?
kerneldrop
South
I'm still in the research stage.
Vihn charges $20 and has a good success rate, although he makes no guarantees.
I only have 1 HDS and the HCRI emitter has a wonderful tint.
My thought is this…use flux gel so less time is required to desolder and then reflow.
Set the small nozzle hot air station to 700 degrees so that I get in and out quickly without the heat having time to spread. I think is where people go wrong is when they use 400 degrees, requiring more time thus allowing the heat to spread. Then just pop off that dome that was the heat shield.
I have successfully done this several times with an import twisty where the driver and LED share the same board. The driver directly is under the LED.
