uncle wong
- Joined
- Mar 5, 2010
- Messages
- 148
Fully agree with your take on AA.
+ 1
Sent from my Nexus 4 using Tapatalk
Help Support Candle Power Flashlight Forum
I still think a good leather holster is the way to go, but then I'm a bit biased. :duh2:
Ah the illusive rotary clip finally revealed. Coolness. That black bit is anodize metal?
Perhaps, we could talk about possible improvements or just changes to already excellent lights.
My complaints are minor:
1. Mode changing is a little slow.
2. I would like to have 5 pre-sets not 4. Say, one for Max, one for the lowest brightness or close to it, one for something like 5-10 lumens, one for 50-60 lumens and one for strobe or SOS.
3. Without, here it is again, clip it rolls like hell on a flat surface.
4. SureFire filters and lanyards are fine but why not HDS Systems filters and lanyards? Or even HDS Systems batteries.
But when you wear a Park Avenue suit, yeah, good clip is needed, but light is not quite secure.
I ordered a custom holster from Hogokansatsukan for my Tactical.
This can definitely be used with a Park Ave suit, securely!
Check out Dan's website for some amazing holsters!
http://m.thorshammercustomleather.c...e395efb8&fw_sig_tier=1&fb_sig_network=fw#2121
Does the set screw on the clip push straight down on the body, like the shaft collar pictured below?
I'm hoping the answer is no. Those set screws will easily mar anodized aluminum.
It pushes on another piece of metal in order to avoid marring the light.
So when this clip is applied to the tailcap, will it rub the battery tube when rotating the tailcap?
If it does, I'd love to see the clip attach to the bezel and sport a 2 way clip.
No rubbing on the body yet one can carry bezel up or bezel down.
Just my 2 cents 🙂
I didn't forget a picture of Nessie. I just got home.
Single AA light is still a definite "no go". Sorry guys.
This is the prototype and is not as nice looking as the finished clip should be for the Rotary. On the other side is a small screw that will apply pressure to the bezel or tail to keep it on the light.
I can't see any solution that attached to or touching the rotating part of the light being a viable option.
