I've yet to receive my first rotary, and without looking the manual wonder if it's the same as the clicky versions. If it is, this is what you do:
- While on (and with programming enabled) , Click and then press/hold to go to particular mode you want to set
- Once there, double-click and then press and hold, when you release the button it will flash twice
- If the output is constant on, press button until it reaches max. Press once more should take you to strobe.
- While in strobe press and hold button. Light will go from dim to bright to indicate mode has been set.
- Double click to go to previous mode. While on, press and hold to test.
