That sounds amazing!That leaves me with the only light I need...a executive clickie that Vinh swapped the xp-l for a 5000k 90+ cri 219b that has a beam so beautiful it came back to me with a fiat lux card! I just can't see needing another light.
How often does the rubber button cover crack? I am considering an HDS purchase, but I imagine this is one of the first parts to go. Has there ever been a metal button cover rather than rubber ?
I don't post often but I have some first hand experience with this one.
I have a 5 and a half year old Clicky with the original flush rubber button. It is currently starting to show some surface cracks but I do not see any signs of this on the bottom side of the button. It is 100% functional and not showing any signs of what I would consider "failing". I am currently only even considering ordering a new button because I am making another order from Henry.
I also need to throw in my support for Henry. In my experiance he has been great. Email responses come within a day and the fact that you are dealing directly with Henry is pretty cool. It's easy to get anxious once you have placed an order and are waiting for a light. I know I did with previous orders but the wait was well worth it. The lights I have are exceptionally engineered and I don't have any regrets.
I don't have many real lights and that is because the couple of HDS light I have are that good. I love to look and get tempted by the forums but i have a hard time justifying getting something else.
I've never had it happen in the 7 or so years I've been buying them, but then I always lose or sell them so the oldest one I have now is still only a couple years old. Anyway, I've heard of it, but haven't seen it.How often does the rubber button cover crack? I am considering an HDS purchase, but I imagine this is one of the first parts to go. Has there ever been a metal button cover rather than rubber ?
As an owner of both I stand by my original statement. If you can't wait for your HDS buy a used one. McGizmo is a different light altogether.Should buy a McGizmo from Don in the meantime and have it on their doorstep in less than a week
gizmo's are very nice, but the HDS for me is just as good.................if not better. The UI on the rotary for example is awesome, both well made,solid lights to last a life time. I would struggle picking being honest, but the HDS is a must imho. Mine thanks to Sean has a 4000k xp-l HI so great tint and good output with programmable driver, so for a gizmo its perfect for me as i like the flexibility of mode options(and more output when needed)
Neither is a replacement for the other, as is common to say "get both" well if there was ever a couple of lights to say that, its these
I almost got a mcgizmo but I wanted the UI of the HDS rotary.
How do you even obtain one? I've looked and can't seem to find a way to purchase one.
Think of the rotary position as one of the options, which most folks keep programmed at setting B (single click from off). Once you double click you're no longer on setting B, so the light doesn't care what the rotary dial position is at. In other words, nothing happens when you turn the dial after double clicking. Once you turn it off and back on to B then it matters again, but not before.
You could also reprogram it so that the rotary position isn't in any of the presets and then the light would never care what the dial is set at
