After playing with it, and watching Thor's videos and reading the PDF and looking at the instructions, it seems I have figured a ot out. There are 4 presets rotary settings on the counter clockwise side. Strobe or tactical as two on the clockwise side. And a double click which is a rotary free setting. Triple clickies g while the light is on is not any setting I have been able to change, but I think I can get used to this.Does this sound right or am I missing some higher function?
Oh, I have no access to setting rotary on the double click setting.
Those parameters are correct for a tactical rotary but not an executive rotary programming. So I would assume you have a tactical rotary.
On a executive programmed rotary the single click is "rotary" operation & 24 different output levels dependent on the position of the dial/knob.
A double click is by default a SOS flash I believe but can be also programmed to any of the 24 output levels or strobe.
A triple click is by default strobe but can be also programmed to any of the 24 output levels or SOS flash.
A click, press hold is max output which also can be programmed to any of the 24 output levels or SOS flash or strobe.
You can also "move" the rotary operation from single to to double click or triple click as well.
You can also 6 click from off & turn the light into a momentary max output only tactical light essentially mimicking a 6P or a Malkoff MD2 without a hi/lo ring. However to exit this mode you must remove the battery & let it sight for like 5 minutes to reset the memory. All the other programmed options remain.
You can also turn momentary mode on & then you can use any of the 24 light outputs in a momentary fashion instead of click on, click off.
That's the bulk of it but that is also more options than just about everyone else along with good efficiency & a heady duty build with a lifetime warranty.
Edit: You can also turn on a 10 minute timer that will turn off the light for you if you accidentally turn it on in your pocket or bag but it also blinks several times before turning off so you have a warning & you click once to reset the timer if you don't want it shutting off.
