indigon
I'm fortunate to have (2) of the rotary 219C 5k 3 o'clock lights, one for work, one for home.
Great tint and CRI on these. Neither has the flashing issue mentioned above.
Nor was I aware of any update to the (proven) V4 firmware.
Ron
Edited to add: I was able to duplicate the flashing problem this morning when I grabbed an older V3 250 rotary.
The light was cold and this rotary has the grating counterclockwise brush issue (the only one I've had with this).
The light was set very low and gave a brief flash when I moved the dial up slightly.
It happened again later when I moved the dial lower again.
The flashing problem seemed to go away when the light warmed up slightly in my hand after using it a while.
Note that the counterclockwise grating issue seems to smooth out considerably also when the light warms up.
My conclusion is the flashing issue is related to the rotary dial brushes skipping around a little on the lower settings.
Not a big deal for me, this is an older beater light that gets very rough duty, I'm a little surprised this light keeps working.
I have some new backup spare rotary dials I will check out on this one.
Edited again (update): Tried a new rotary dial on this old light and the problem went away. Smooth as silk now.
Will send the old dial in on my next firmware update, no doubt Henry will make it right.
Ron
