HDS Tactical Rotary 325 Factory Brightness Levels
Candle Power Flashlight Forum
Help Support CPF:
I had a tactical one, and somewhere in HDS topics this question was already addressed.
There 1, 3, 5, 7, ..., 19, 21, 23. If you transfer tactics to level 12 (level in the sense of the number of the physical rotary sector, not the brightness level) and press the button and hold it, you will see the next jump - level 24.
There 1, 3, 5, 7, ..., 19, 21, 23. If you transfer tactics to level 12 and press the button and hold it, you will see the next jump - level 24.
Thanks a lot!
I cant find his model, but here is what that link says.. .03/9/48/250
Other than max (Preset A), are these the stock clicky settings? If not, anyone know where to find the stock settings? Not lumens per level 1-24, but the default levels for Presets A - D.
post 13 has the lumen levels on the tactical dial..
the manual has the clicky presets:
EDCTM TacticalTM Flashlight Advanced User’s Guide
Tactical:
• Preset A: maximum
• Preset B: fast strobe
• Preset C: brightness level selected by rotary control
• Optional features: Burst, Pseudo-Momentary
Sorry, but I think no one post is right describe levels))) because user guide says there is 24 levels same as in regular rotary, and in my understanding you can setup any from them on your 12. So what levels came in factory settings?
the yellow lines are the factory presets, pic is a link to more details
my understanding is that the 12 levels cannot be reprogrammed.
I think the tactical 12 levels are the odd numbered levels out of the 24
glad it helps you both
you may also like these rotary position, output correlators.. I added the lumen values from the tables, at the 50% and 75% rotation positions
lumen levels for a High CRI 200 model
these are the odd numbers of the 24 levels on a 325 tactical model
The answer to my question was not found 🙂 The table is not applicable to rotors with 12 brightness modes.
The 12 steps on the tactical dial are the odd numbers on the output chart..
read chart lines 1,3,5,7,9,11,13,15,17,19,21 and 23... (those are the 12 levels on your tactical 325 dial)
does that help?
or maybe I do not understand your question well enough yet...
does that help?
So, in that case there is no maximum (level 24) at the position 12 of the preset "C"?
I believe that it have to be there, because if you turn off the "burst" mode it must be at highest level all the time.
correct, that is what I believe is correct
if Im mistaken, I hope Hogo will educate us better
there are a few different ways to get to level 24
here is one you may find useful:
from on, double click,
that will toggle Preset A and C
correct, that is what I am saying.. if Im mistaken, I hope Hogo will educate us better
fwiw, I can think of at least 3 different ways to get to level 24 on a Tactical Rotary, and one of them IS on the dial, its just not at position 12.
I do not know how to get level 24 in 12 steps, unless some other level is being skipped..
Thanks.
Ok, I’ll wait for my HDS to arrive, then I’ll continue to research))))
That is correct. Maximum (24) is only at the end of the dials rotation after strobe. The 12th step is level 23.
