headlamp for grilling and fishing
K
kamikazil
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
3) Format:
____I want a self-contained headlamp.
4) Size:
____I don’t know/I don't care.
5) Emitter/Light source:
____I don't know.
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I don’t know.
14)Material/Finish/Coating
____I don’t care.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
16) Storage conditions
____In house (temperature/climate controlled environment)
Similar threads
G
Replies
Views
647
ghause
G
T
Replies
5
Views
1K
inrealtime
I
S
Replies
3
Views
1K
sierra 18
S
W
Replies
Views
1K
wongus
W
