gcbryan
I emailed Black Diamond to ask how they can come up with a run time spec for the Storm on max (100 lumens) using (4)AAA's of 50 hours.
Of course if you break it down by battery capacity and emitter wH requirements on high you get something in the 4 hour range.
Their answer is that they use an outdoor industry standard used by other manufacturers to allow for fair comparisons between competing products. That standard is to turn the light on (high) and measure the time until the output is down to .25 lux at 2 meters (moonlight equivalent).
Not much of a standard in my opinion. Someone with a true regulated light rather than just the first 25% of battery capacity (Storm) would show 4 hours using the same batteries and emitter as the Storm.
It would be OK as a standard if that standard was mentioned along with the 50 hour figure.
When someone is thinking about buying a headlamp that produces 100 lumens I don't see how telling them it has a run time on max of 50 hours tells them anything at all.
