Headlamp(s) and Bike Light for Adventure Racing
SettleNow
For those that don't know, adventure racing is a sport in which small teams (2-5, occasionally solo) race on an unmarked course, navigating by map and compass. We are usually looking for an orienteering flag, which is sort of like a three-sided cloth box kite that is white and orange, and sometimes reflective. Of course, along the way we could be looking at/for maps/charts, instructions/our gear, signs, marine navigation markers, trail openings, changes in vegetation (so neutral color valuable), etc. etc. We are moving on foot, on bicycles and in canoes/kayaks. SO, lights need to be waterproof, light weight, long lasting, capable of good throw, very reliable. I mostly race in warm climates so extreme cold not a likely factor. Need at least two lights -- a headlamp and a light to mount on bike handlebars. If one headlamp can go over helmet or heat with hat, great. If not, can leave a helmet mounted light with bike for access in transition areas. Races last ~12-~72 hours. Of course, about half that time or more no artificial lighting is needed.
NO PREFERENCE
____I would like to purchase the light in person from a brick and mortar store. I am located in South Florida.
____This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
_X___I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
X____I am not sure, please help me decide.
____I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
SEE ABOVE -- SMALLER AND LIGHTER IS BETTER BUT NEEDS ADEQUATE BURN TIME AND THROW
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
X____I don't know.
6) Manufacturer:
SOMEONE RELIABLE
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
OPEN TO SUGGESTIONS. ABILITY TO EASILY GET REPLACEMENTS IS NICE, BUT SO IS NOT HAVING TO ADD TO LANDFILLS
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
X____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
SEE FIRST PART OF POST -- FOR HEAD LAMP FROM READING A MAP, TO LOOKING FOR A ONE FOOT OBJECT 200M OR MORE AWAY FOR HANDLEBAR LIGHT -- ENOUGH TO MAKE OUT TERRAIN VERY QUICKLY FROM A FEW FEET AWAY TO 30M AWAY
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
MOSTLY THROW FOR HEADLAMP, MIX FOR HANDLEBARS. PLEASE SEE FIRST PART OF POST
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
HEADLAMP -- MIX BUT INCLUDES 100+ METERS; HANDLEBARS -- 5-30M
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
X____50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
X____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
CRITICAL TO VERY IMPORTANT. REMOTE AREAS. FATIGUE. RACING.
____Not Important (A "night-stand" light).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
OPEN TO SUGGESTIONS
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
x____I don't know.
OPEN TO SUGGESTIONS. EASE OF USE IMPORTANT.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
TI SOUNDS NICE BUT OPEN TO SUGGESTIONS
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
IMPORTANT
____None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
X____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
PROBABLY IN HOUSE BUT WITH LONG STAND BY PERIODS AND IN A BIN DURING RACES OR TRAVELING TO AND FROM
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
THANK YOU FOR ANY SUGGESTIONS.
2 thoughts:
1st: seems like what is my personal "must have": small and light
2nd: "normal" batteries have only one advantage: You can get them in shops "somewhere", if needed ...
Will You have acces to recharge batteries?
so no monthlong hike at some remote area?
Then easy: 18650 Li-Ion battery as power source and both lights to run with them ...
Headlamp: Zebralight H600 MK2 XM-L2 neutral white
handheld: better "18650 P60 host"-body (starting with Solarforce body) and a P60 led insert form member nailbender (see sub forum Custom and modified for his threads).
personal advice: sheer max output is not needed, have the max set to 800 mA by him, then You have Your three hours.
Led: Cree XP-G2 will give a "brighter" beam with more reach (because the main beam is just half as wide), on the other hand
a Cree XM-L2 will gibt the "better", wider beam (which You already have from the Zebralight)
whatever You get, try it with 5.000 Kelvin color, that matches the warm Zebra quite good...
other idea:
XM-L2 insert with "normal" max (2.8 A), so You will have that ~ 800 mA to get a 3 hour runtime at the medium level.
So - if needed - You can power the thing up on full for short time high output illumination, while normally You use low and med level ...
[edit]
on the bike I use my zebra - bands set wide enough to fit over my head - simply by pulling it over the helmet
(sometimes with an additional "safety rubber band" through the holes of the helmet)
+ the handheld mounted on the bars with a holder
for me, much better than any high output light(s) used by my friends ...
[/edit]
Don't be afraid to go the 18650 battery route. I knew nothing about flashlights or batteries and I pulled the trigger on a wizard pro headlamp that runs off of an 18650. $20 charger will charge two batteries and it also comes with a cigarette lighter adapter. $10 per unprotected battery and I think it's MORE convenient than running to the store for batteries. The run times are very good and I know everyone has run out of batteries, I'm yet to run out of electricity to charge these batteries haha. Even on the go.
Correct, not expecting to be away from electricity for a month. At least not until the zombie apocalypse. Guess I should add a solar panel for that? P-) Thanks for info.
