First post- glad I found this forum instead of the conjecture based responses Ive seen in other forums. I have a 2002 Ford Ranger with 9007 style bulbs. Im heading into winter, and my headlights pretty much suck. Every vehicle Ive ever owned has been known for having terrible headlights, and I want to fix that as best as possible. I live north of Austin (hill country) where tons of dark roads are occupied by tons of deer. Ive nearly wrecked my truck twice because of my headlights.
Originally, I was going to retrofit HIDs, but with the glare Ive been forced to see from others and the fact Ive hated every HID setup Ive been behind when raining, Ive decided to stay halogens. I have learned from these forums:
1) Avoid blue tinted bulbs. All they do is filter out yellower light to give a whiter appearance reducing light output in the process
2) HIR bulbs are great, but cant use them with a 9007 style housing
3) Priority 1 is to remove any haze from lenses or replace assemblies; ill be polishing the lenses and sealing them and redoing as needed.
4) Bulb output is exponentially increased as voltage is increased, but bulb life is even more exponentially reduced by voltage increase
5) Phillips ExtrmeVision are the best halogen bulbs available on the market for 9007
6) Voltage drop via small wiring and worn contacts in the OEM headlight wiring can produce voltage drop and reduce light output
So, I have some questions for you guys.
Do you think its excessive to use ExtremeVisions with a headlight wiring harness kit (it would be either done by me or one from rallylights.com)? I drive a fair bit at night, so im not sure on the longevity of this setup. What kind of life could I expect with this setup? My output at the battery is around 14.2v- I would imagine the bulb life with ExtremeVisions and a harness would be around ~150 hours (assuming 14.2v at the bulb)?
Would I be better served getting some long life halogen bulbs and pairing them with a headlight harness, or with keeping the stock harness and getting the ExtremeVision bulbs and no harness? I would guess the bulb life might be around ~600 hours?
Its one thing if youre in a high performance sports car and need the best performance you can safely get. Its another in a Ranger where I tool around at 55-65mph rarely ever bothering to break 70mph. Curious as to where I should draw a line (yeah I know its a personal choice), whether Ive got my facts right, etc.
