Radio
Modulated Moderator
Wal-Mart sells 5200 BTU window units for $50 or less, end of season they are $35 or less, I stock up then, This is NOT a good time to be looking for one though.
Radio said:Wal-Mart sells 5200 BTU window units for $50 or less, end of season they are $35 or less, I stock up then, This is NOT a good time to be looking for one though.
ABTOMAT said:It's about 95-100 here in MA right now. I don't like AC so I don't use it. Rather, I like being _in_ and air conditioned house or car, but the transition is too hard for me when I go outside. Screws up one's natural balance to be in the cold all the time. It's also too humid here for a swamp cooler. They're a good deal out in Arizona, etc.
I am, however a big believer in fans. Right now I have a big '50s Hunter in the kitchen, a '60s Ambassdor in one bedroom, an '80s Sanyo in another, a '90s Vornado heater/fan in one bathroom, a small '60s GE in a downstairs room, and a huge '50s GE upstairs pointing out a window. Close up the house in the morning, ventilate at night when the temperature and humidity goes down. My old house had one of those 3' diameter whole-house vent fans in the ceiling. Wish I could put one in here.
Currently restoring a '20s Emerson and a '50s Vornado pedestal. Plus have a '10s-'20s Polar cub on standby.
Oh, and a dehumidifier in the basement.
Different people have a different "comfort zone". I've known people who set their thermostat for 90°F in the winter because that's what they feel comfortable at. With the obsession to set the thermostat at 78 or so to save energy I personally find most stores and offices these days too hot for me, all the more so when one is moving around. My own "comfort zone" is about 70 to 73 when I'm sleeping, 65 to 68 when I'm awake but fairly sedentary, and under 60 if I'm somewhat active. This is generally too cold for most people. I'm guessing it feels OK to me since my normal body temperature is around 97°F. I'm just setup for cold climates.B@rt said:I'm sure I'm in the minority, but I prefer a fan over AC... Most people set the temp way too low.
JLavino said:You are crazy, its 100+ today in MA. I require AC to stand in this weather! Good luck with your fans!
jtr1962 said:Different people have a different "comfort zone". I've known people who set their thermostat for 90°F in the winter because that's what they feel comfortable at. With the obsession to set the thermostat at 78 or so to save energy I personally find most stores and offices these days too hot for me, all the more so when one is moving around. My own "comfort zone" is about 70 to 73 when I'm sleeping, 65 to 68 when I'm awake but fairly sedentary, and under 60 if I'm somewhat active. This is generally too cold for most people. I'm guessing it feels OK to me since my normal body temperature is around 97°F. I'm just setup for cold climates.
I dislike fans because they blow dust everywhere and don't do much in humid climates like NYC. The only people who can get by here without A/C are those with a naturally high tolerance to heat.
you might try slowly creeping the temperature up over time and give your body a chance to get used to it.
I just don't get used to heat. I completely lost my tolerance for it about 13 years ago when I helped one of my neighbors with his kiddie entertainment business. We were outside on some of the hottest days. I found by the end of that summer I literally couldn't cope with heat any more. Another problem is that I get rashes whenever I sweat so I have to avoid sweating. I personally don't see any good reason to turn up the AC to 80. The energy savings would be nil once you count the extra showers and changes of clothing. As far as keeping it warmer to avoid the thermal shock when I go outside I just don't go out in the summers except at night, and then only on days when it drops under 80. The poor air quality is the main reason but I need to avoid excessive heat as well.ledlurker said:you might try slowly creeping the temperature up over time and give your body a chance to get used to it.
I guess you just have a high tolerance to heat. We used to rely on fans when I was a kid. They didn't help me much even then, and I had a higher tolerance to heat. As for the dust, you would be surprised how much accumulates in even a week. Unless I want to make dusting a full-time job, fans will be blowing dust. Unfortunately lots of dust comes up from downstairs as well. My late father left the basement in the state shown below which is essentially a garbage dump:B@rt said:I've stayed in the tropics, and even though humidity was high, a fan still worked well. If it blows dust everywhere, maybe vacuuming would solve that?
