The design parameters for thermal management of LED headlamps is no different than thermal management for any other LED device.
Who's ever seriously and knowledgeably debated this…?
It's an engineering problem, not a technical problem
It's both, actually. Remember, automotive service means constraining factors of cost and packaging and physical and environmental robustness come into play; they have a way of making technical problems that wouldn't exist without those constraints.
I'd appreciate it if you'd stop claiming otherwise simply because BMW/Audi/Mercedes, etc. aren't owning the technology.
I'm not sure how to respond to this because it's unclear what you mean by it.
I also recall you stating in other threads that the lack of thermal produced by LED's represented a problem in snow / ice, so, which is it?
It's both, actually. The challenge is to move heat from the backs of the emitters (where it does harm) to the front lens of the headlamp (for thawing)…and to do it as effectively, simply, reliably, durably, inexpensively, compactly, and cost-effectively as required by the specific parameters of the lamp and vehicle being designed.
In Cree lumens I've calulated the surface area for simple wrap around headlamps could produce lumen values over 1,500 at 115F ambient, which is well beyond what the best halogens can achieve, especially photopic. This is entirely passive and doesn't assume anything internal aiding thermal transfer.
Those are nice numbers. Perhaps you can explain, with support for your assertions, why today's best LED headlamps (e.g., Mercedes and Audi)
don't approach your calculated numbers and
do require specific design features and components for thermal management.
Like anything else in the automotive industry LED add-ons are going to be treated as any boutique item that dealers can make a quick buck off of.
It will probably be more productive if we keep the focus of this discussion on OE headlamps and other serious products without looking at aftermarket toys and fashion accessories.
Current Halogen / HID fixtures are injection molded for a coupla buck in Mexico or Asia
The very simplest, most basic headlamps, yes, but in general, no; surely this isn't your actual impression of the costs and techniques involved in the design, tooling, and production of an OE current-model halogen or HID headlamp…? If it is, you are far off base.
the optical designs for these current lamps are primitive and based on flashlight params.
That is flatly not correct. Not in any kind of a general way. It doesn't apply to any of the OE LED headlamps presently on the market, though it could legitimately be applied to the Truck-Lite 7" round unit. It appears to me that you don't have very close familiarity with the optics of the OE LED headlamps presently on the market and forthcoming in development. That would explain some of your other statements, which appear to be based more on guesses and assumptions than actual knowledge.
biking enthusiasts are building more efficient and likely better color rendering LED lights for off road use. Some are likely brighter than your stock European halogen.
Perhaps, but perhaps not. How about some support for the assertion, in the form of beam isoplots, colorimetry test results, and other hard data? Also, you mean "brighter" in what sense? Total flux in beam? Peak beam intensity or illuminance? The term "brighter" is not formally used by those actually involved in engineering, making, testing, or studying the performance of headlamps, because it is a subjective term (like a
louder sound or a
stronger smell or taste) with no quantifiable meaning.
