Hi,
I recently moved to Sierra Leone in West Africa, in fact I drove here from the UK but that is another story! I have always been convinced that LED is the lighting technology to help bring light to parts of the world where it has been previously unavailable, it is bright , rugged and uses very little power so it is an obvious choice for off grid use.
There are a range of cheap REALLY badly made flashlights here; some like traditional flashlights and some area lights usually featuring arrays of LED's. They are badly made, flimsy, don't last long as they are fragile and use disposable batteries which is terrible for the environment.
I think that we can do better and I think that with a good enough spec you could produce something that could really change the way a lot of people live their lives.
I see the perfect light as:
- Cheap
- Solar or renewable powered I don't like the wind up things but the rip cord ones don't seem bad, solar is probably the obvious choice.
- Featuring either an in built battery pack that is rechargeable or possibly the ability to put in one or more standard rechargable NIMH batteries. Maybe it could have the option of running of say regular AA (or other) disposables or from an AA rechargable cell that the renewable power source charges. The rechargable would have to be capable of being topped up constantly from a solar cell and would also need to be capable of thousands of recharge cycles.
- Able to act as an area light attached to the roof of a hut so that the family can cook etc after dark. this probably means having the light on a flying lead with the switch mounted on the light itself or the battery pack.
- In a perfect world the system would be modular so you could add to it or replace bits as necessary.
- Several brightness levels but not necessarily regulated, I am not sure what this would do to the cost though.
- The battery and light would need to be capable of being run for say 6 hours per day each day but it wouldn't matter if this was from a full charge to completely empty.
The way I could see the product being set up is with a small solar cell on the roof with a lead running to the battery pack and a further lead or leads powering the LED's. It would need to be cheap enough that it was affordable to people with very little money. Although it needs to be cheap, at the moment peoples only options for lighting rooms are very expensive generally. A generator or a big solar pannel and car batteries combined either with very innefficient incan bulbs or very expensive ennergy saving ones. Cost for such setups range between $50 and $1000's depending on how much light you need.
I am doing some research at the moment but everyones thoughts on what the spec or components for such a light would look like would be really good.
Specifically; if anyone can suggest what cheap wide angle LED or LED's would be appropriate and also what battery capacity or type would be suitable then that would be great.
Thanks for any help
- Cheap
Thanks for any help
