I have been spending a lot of time looking over various flashlight reviews and such, and I've finally decided that it might be a good idea to consult the members here at CPF on my first post.
After making a few LED lights (Radioshack and Home Depot, yeah!) and playing around with a M@G-lite that I modified with a lens from a telescope set and a LED drop in (apparently it was just an LED of some sort (Luxeon? I can't know for sure) on top of a machined aluminum heatsink driven by what seems to be a resistor/heat-limited resistor; I have pictures from when I took it apart and added some cheap thermal grease from RadioShack) I'm sort of hooked on the nice beams of LED lights and was hoping to get something a little smaller to play with.
As I'm only a teenager, my budget is limited to about $20 - $30, and this would mean that I'm only able to get one flashlight, so it's important that I get it right the first time. ("even though it's probably not going to be the last"; I just know someone is going to say that here)
So, requirements: a 2XAA (NiMh) flashlight with a runtime of at least 3 hrs. For the beam, something that has spot to flood capabilities. In the case that that isn't possible, then a light who's spillbeam is fairly bright (proabably an OP reflector) so that it floods more than throws. It also doesn't have to be horribly bright , but it should be equal or surpassing my modified M@g. (I'm not sure how I would tes this though, I can provide pictures if it would help in assisting me)
I haven't found any 2xAA focusable lights (besides the COAST Led Lenser, but I'm not to sure about the runtime on 3xAAA and the price is too much) so I've been looking at the Romisen RC-N3 from DealExtreme, since it does use 2x AA, but I'm not sure if the spillbeam is bright enough for what I'm looking for.
<bad pun>I'm sure someone can shed some light on my situation.</bad pun>
I don't like sounding like I'm flat out asking for help (and I bet others don't either) so hopefully someone can just confirm my research or recommend a different direction.
Thanks in advance,
aEx155
Thanks in advance,
aEx155
