Help, I need a converter for my bike light.
Lumbee1
I built a dual CREE bike light and need a suggestion for a converter.
- Pair of CREE's in serial (~3.4Vf each) for 6.8Vf total
- Li-Ion battery pack 3.6V
- 750mA is ideal but anywhere from 600 to 800 would work as well.
- No need for dimming and I hate UI's.
I built a similar light with a Fatman that works great. I was looking for something that was set it and forget it.
The GD looked promising but it won't support anything above of Vf of 5.4.
Any other suggestions?
Why do you want to use only one Li-On? Whay not 3? :) I think it is easier to Buck, not to Boost ...
a Buck converter would give you better efficiency, but just put the LED's in parallel and get 2 750mA boards, unless there is a 1.5 amp board I am forgetting about.
does not sound like a problem: 2 emitters = 1 Lux V.
Get a Badboy or Badboy Nexgen from the sandwich shoppe.
(high possibility You have to order one suitable for Your needs --> have the fitting resistors soldered on)
Also a source for reflectors for the cree. Much better than the optics imho.
16 or 17 mm McR-XRE is what I recommend, 19 mm for more throw but a bit more tricky to mount.
