Help Identifying Eiger Marking
pmek5
pmek5
Clovis, CA
Could not find a thread to answer this - I have an Eiger Head with an "N" on the battery contact. Can you please tell me what the "N" is for. This came with a 10180. It is a heck of a lot brighter than my level 1 I currently run on my 10180.
Theatre Booth Guy
Theatre Booth Guy
Michigan, USA
Normal maybe? They did have L for low, S for super, U for ultra and it seems like there was something for ultra-low. Out of what I listed, regular power seems missing thus, my N for normal guess.
Someone here has to know. The new number system is much easier
J
jabe1
Cleveland,Oh
It is probably a newer neutral LED model. N for Neutral.
archimedes
archimedes
Moderator,
Staff member
CONUS, top left
I would agree with jabe, especially if you are pretty sure this is a newer LE (& came with the 10180 QTC tube originally). If so, this would be equivalent to a "#8" (max) in the prior system.
Most of the other letter stamps were for the original system, which pre-dates even the number system....
pmek5
pmek5
Clovis, CA
I have an older Level 1 head which works great with an AW 10180 battery. With this head it comes on at a level 8 (using the old number system), and then drops to about a level 4 or 5 after five seconds. Will this battery work alright without a QTC (this is just a standard 10180 body that came with it)?
archimedes
archimedes
Moderator,
Staff member
CONUS, top left
I think that "H" (high) was what was actually originally used for "normal" :thinking:
archimedes
archimedes
Moderator,
Staff member
CONUS, top left
There are (at least) two reasons for the output drop you've noted - voltage sag from the significant current draw on the tiny 10180 cell, and minimal mass for heat-sinking on such a small light affecting the emitter temperature.
pmek5
pmek5
Clovis, CA
I understand the voltage sag, but the other I don't. Is the second explanation going to harm anything? I got to believe Peak would not have sent a set-up that was not going to work properly.
archimedes
archimedes
Moderator,
Staff member
CONUS, top left
Well, one advantage of the QTC is that you don't have to always run "full-blast".
The 10180 cell will not provide very much runtime at max, so thermal effects on the emitter may be somewhat limited just due to that fact (but excess heat is not good for LED longevity, in general).
If it's getting too hot to hold comfortably, it's probably not great for the emitter....
ElectronGuru
ElectronGuru
Oregon
With the advent of the QTC, Peak is shifting away from power levels (1-8) and to LED indication:
C - cool
N - neutral
H - high cri
R - red
pmek5
pmek5
Clovis, CA
I am still puzzeled how well this will work not being a QTC, and a standard AW 10180 battery.
Similar threads
T
Replies
3
Views
3K
thunberg
T
G
Replies
63
Views
12K
Derek Dean
Derek Dean
V
Replies
5
Views
6K
LRJ88
L
mcbrat
Replies
6
Views
9K
mercurialpissings
M
DUMDUM
Replies
16
Views
5K
FatRat
F
