If the guts are a McClicky, there should be a metal plate under the plastic pedestal the spring sits on. In that metal plate there are two grooves, directly opposite each other. Put the tips of your needlenose in the grooves, press in lightly, and turn left. The metal will take a good bit of torque, but the entire unit should unscrew once you get it started.
