archer6817j
Hey all,
Not quite sure where to post this but I think setting trits counts as flashlight related materials...?
So I bought a UV dental curing light off eBay because I was going to simplify my life...and tritium installation. Figured the high intensity would cure Norland in a jiffy and I wouldn't have to leave my parts out in the sun for an hour to set each trit.
I got it all cleaned up and put down my first test blob of Norland 61 and...it didn't cure. After some hard googling, I found out this older model dental lamp puts out a different spectrum than I need. The light looks nice and blue but it's something like 400-500nm. I let the light run for several minutes and the Norland didn't even begin to cure. I have a (weak) 365nm LED light and I put that on the Norland just to make sure it actually worked and the Norland set up fine, so it's not the Norland, it's the light. The LED light is waaay to slow so that's why I'm not using it.
Okay, no problem. I went to Edmund optics and ordered an 85% transmission 365nm bandpass filter. It's supposed to take visible light and block out everything but 365nm (give or take a little). My dental light has a halogen source. Looking inside the little cap that came with the light I can see a filter that looks exactly the same as the one I bought. Perfect. White light in, blueish UV light out. However, when I unscrew the old filer and stick my new bandpass filter in front of the output on the dental light...I get almost no light at all and it's not remotely the purple/blue of 365nm UV...and it has no effect at all on the Norland. The filter has an arrow that shows the direction of light. I tried flipping it around. Nothing.
It seemed pretty straight forward. Remove old 450nm bandpass filter. Install new 365nm bandpass filter. Cure Norland.
Anyone have any experience and/or thoughts on why this doesn't seem to be working?
