Hi all,
I've a problem with my 10W HID system. It is a system sold by a bike shop called 'The Rush' in the UK, basically a trailtech 10w HID housing/ballast/bulb with a custom voltage controller/switch added in.
A month or so ago it failed totally, I took it apart to find a broken wire was the cause. I resoldered the wiring and all was fine for 4 or 5 rides.
Now the light runs for about 5 min, the turns itself off, even on a freshly charged battery. It started doing this in the middle of a ridewhen it had been on for an hour or so. It will turn straight back on again when the switch is pressed, but again only runs for 5 mins before turning itself off again.
any ideas what may be the cause? Would a problem with the ballast cause this or does the ballast just control start up?
any help would be much appreciated.
