flightmate
- Joined
- Apr 22, 2021
- Messages
- 17
New here, and been doing as much research as I can before buying a more expensive flashlight. I have narrowed the list down, but want to make sure I'm not missing anything. Hoping some of you with more experience can steer me in the right direction. Here's what I'm looking for:
* EDC flashlight- day to day normal uses, plus some hunting, camping etc. 200 lumens is more than enough. Would like it in a warmer tint. 4000k or so. Around the house, I really use the lowest settings on my current lights the most- especially moonlight mode.
* Size- I carry a Olight S2 Baton II right now. So about .9 wide by 4 inches and weighs 4oz. Would prefer it to be smaller than that, or at least not much bigger.
* Has to have a good clip, tailstand, and tail switch or twist operation is preferred. Battery type doesn't matter too much.
* Well built, good warranty, made to last a lifetime. If I'm potentially spending this much, I want something that is built to last. Simple, rugged, and easy to repair or even upgrade if needed.
* Budget is up to $500 or so.
So far it seems the most widely recommend are HDS Rotary, and the Mcgizmo Haiku.
I like most everything about the Rotary, but the clip. Does the universal clip work well? Seems really long and sticks far out in the pictures.
Haiku also seems just about perfect except I would really like a moonlight mode if possible. Does the newer HIVE version go lower than 1 lumen?
Thanks in advance for any help, and please let me know if there are any other options out there that fit what I am looking for.
