SAVAGESAM
Ok, I got my rechargeables in and......nothing. I put the 123s in and light works fine. I checked everything I could think of. I need help from those in the know. TIA
AW protected li-ion, 17500, no idea, and a Bug out gear Cree Q-5 LED. I waited over 24 hours after charging to let them settle.Which cells did you get, what size, what voltage are they reading, and what lamp assembly are you using.
He should be using two 17500's with a voltage of 7.4 or up to 8.4 hot off the charger.does the BOG LA run all the way down to 3.7v?
