refinished
- Joined
- Oct 30, 2007
- Messages
- 2
Hi all - I have a LED module out of a UKE SL4 that I am trying to use in a different light body. The mechanical fit is fine and the circuit works as desired, but I need some assistance with the powering of the LED. The SL4 is a 4 c-cell light and the new body is a 2 c-cell. The LED is much dimmer in the new body with the 3v disadvantage. The local BatteriesPlus has 3.6v Lithiums that are c-cell sized. Using those would put 7.2 volts to the LED. The question? Is there danger to reliability or life in using the 3.6v batteries in this light? The application is cave diving, so the light MUST work. Other options I have not considered?
I tried to understand the 'LEDs are current devices, not voltage devices' threads, but it's not exactly 101 level stuff. :shrug:
