Help: Understanding Battery Stats
blerkoid
Hello CPF,
I am hoping someone can help me better understand the information displayed by websites regarding batteries.
I recently ordered four of the following:
Samsung INR18650-20R 2000 mAh High Discharge Flat Top
Specifications:
Nominal Capcity: 2000 mAh
Nominal Voltage: 3.6V
Discharge End Voltage: 2.5V
Standard Charging Current: 1.0A
Charging Voltage: 4.20+-0.05V
Max. Continuous Discharging Current: 22A
Internal Resistance: less than 15 milli-ohms
I understand this to mean I should not charge the battery above 4.2v (overcharge) or let it fall below 2.5v (over-discharge).
Can someone please confirm or correct my current understanding?
Is there anything else I should be cognizant of with the above information?
Thank you in advance!
Lou Minescence
New England US
Sounds like you have the max charge / discharge voltages figured out.
I question this spec
'Max. Continuous Discharging Current: 22A'
Maybe it's me. I'm not sure.
vicv
Southern Ontario
The max continuous discharge is correct. That's a good battery. Also it's telling you to charge it at a max of 1A. It's capacity is 2000mah. Meaning a 2A load on it will last 2 hours before dead. And 1A for 4 hours. Ect. Also the 2.5v discharge is under load. Don't let the cell be less than 3.2-3.3V when tested out of the light with a multimeter. I can't think of anything else. Oh. 3.6V nominal voltage. Over the entire discharge of the cell the average voltage will be 3.6V.
