Well, I got this charger because it's supposed to be one of the best and it was cheap, well cheaper than retail. But I'm already having doubts. One being they have no US phone support, and I think I already fried a battery pack.
Right now I only want to charge 6-7 cell nimh packs. And yes, I read through the instruction booklet more than once.
So, right off the bat I'm having probs. I followed the instructions to do an autoDC refresh and it would only charge at around 200-250ma. From what I could make out in the booklet it says you can't use the auto charge feature because of that problem??? And their instructions say you should always charge at 1C or above. I thought you wanted to charge around .5 to .7C?
So, I thought I would try to manual fixC charge. 4200mah 6 cell pack, set charge to 5amp, cutoff sensitive, delay 5min, 6 cell, 5000 capacity, refresh on. Finished charging and said it charged about 1/4 capacity. Ran my stampede for about 7minutes.
Then I tried to charge another 6 cell 3000mah pack, which possibly was on the verge of exploding after this.
I thought I would try the manual refresh cycle fixDC. Set current to 3amp, discharge at 2amp, 6 cell 3600 capacity refresh on. It was charging for probably less than 30 minutes and then the charger started beeping and it said warning #4 disconnect battery. The battery was HOT, too hot to touch for more than a sec or so. Guess what, no info in the manual or their website about errors, at least I couldn't find any.
I really hope someone has some experience with these, because for as much as these retail for, it already causing way more probs than MUCH cheaper chargers. I would think just charging some old nimh would be real easy.
I hope I'm doing something wrong.
