Help with Arc White
BugLightGeek
St Louis
I have an Energizer Arc White flashlight that I need some help with.
The lens has clouded over (I think due to heat - from being left on; courtesy of my 2 year old
). I need to replace JUST the plastic lens. I called Energizer and they said I could send in the entire light but that it would be 6-8 weeks!
Plus, they said they could not simply replace the lens.
Does anyone know another source for this lens? What about the exact specs for the lens?
Thanks!
Originally posted by ChrisM:
...The lens has clouded over (I think due to heat - from being left on; courtesy of my 2 year old
). I need to replace JUST the plastic lens....
Thanks!
<font size="2" face="Verdana, Arial">im curious about this as well, as mine has done the same
Maybe it's good that I replaced the lamp with a LED right after I got it.
I'm suspicious that's it's because it is plastic but can't confirm/deny that.
Anyone have any sources for a replacement or alternate lens?
I hope this doesn't happen to mine! I know it's a 'cheap' flashlight, but I really like mine, especially with the CCFT. Maybe the guy who makes glass lenses for other flashlights could make one the size that would work for the Arc White.
Hi I just joined forum I'm having trouble finding the right bulb for the energizer arcWhite
Does anyone know what the # of the bulb is for normal or LED bulb the ones I got dont work
You need a 4.8v pr based incan bulb (4 cell) or a 4 cell LED pr base bulb, one place that has it is walmart for $3.88 but they are nothing spectacular IMO.
