milkyspit
This is about my computer motherboard, not a flashlight, but I need technical assistance understanding a possible problem from the electronics gurus around here. Lately my PC has been randomly freezing, rebooting itself, and similar things. I thought it might be a buggy kernel mode driver in Windows 2000, but today the whole box rebooted with no warning, for no apparent reason, and I popped the hood (so to speak) to take a look inside. I thought maybe the CPU fan had failed.
Everything looked pretty normal, and all fans are working, but I noticed something strange: several electrolytic capacitors on the motherboard have varying amounts of hard, crusty green stuff on the tops. I've never seen that before. All the capacitors on this motherboard have crosses scored into the round metal tops, as if they're designed to "blow" gracefully or something. It appears that the ones with the green stuff have tops that are slightly bulged outward, and it's entirely possible that the leakage (if that's what it is) came out the center of the score marks. The non-leaking capacitors don't appear to be bulged outward at all.
My question is, what's going on... can someone tell me what's likely to have happened, as well as how such a thing might happen? Would a power surge do it? Seems strange because this system is running off a power strip with built-in surge protection as well as a UPS. What about overheating? But I've run cases hotter than this one with no such problems, plus I'd imagine the CPU itself or perhaps the graphics circuitry would be showing adverse effects of overheating far before capacitors on the motheboard would pop.
Or maybe this motherboard is just a pathetically designed piece of crap?
For what it's worth, the motherboard is an MSI K7N420 Pro with nForce chipset. It runs an AMD Athlon XP processor.
Do I have a problem here?
