Help with leadlight!
Treacle
Just got a new leadlight from Vitalspirit and when I adjust the pot it gets alot brighter but then goes dim and turns into two smaller dots! What could cause this? It's goes bright again when left off for a few seconds then just does it again.
try turning the pot down again.
remember, diodes CAN be over driven, weakened, and burned out.
I did and it works ok. So what, I can't modify this one? The diode must be complete SHITE!
perhaps you have a 110 with feedback sensor.
do you see a red indicator led inside?
green plastic wrap around the driver board?
2 wires dangling off the board and along the barrel?
these would indicate you have a feedback sensor to destroy.
No it has none of that. My lightvision one does though! What do I do just unsolder the read and black wires?
